Online: BigKangaroo
2012 sportster low 883
  • Birky
    Birky
    Hey there mate I have a 2012 sportster low 883 I have fitted a hiflow air filter and a set of v&h short shots
    I have a fuel pak and am using FP-4927 map, it seems to be missing and cutting out when I accelerate (it was like there was no fuel getting to the motor)
    Is there anything I can do to make it run better or has anyone else has anyone else had this problem
    when I removed the baffles and remaped the fuel pak it run worse
  • Rocky2010
    Rocky2010
    My partner has a 2009 883 Low with a V&H FuelPak its running the FP-0687 map which runs well
    Bike has a RSD Air Cleaner and V&H Shot Shots Staggered exhaust with Stock ECM Callibration setup
    Bike runs well, not sure if they change anything on the 2012 model,
  • dedge
    dedge
    You might want to get an Air fuel reading its sounds like it's lean
