Online: Trunksie
trickle charger
  • brush
    brush
     after a trickel charger so i can attach permanant leads to battery and just plug in, chasing any info on good brands , CHEERS  BRUSH
  • crookneez
    crookneez
    CTEK XS 0.8 for about $70 http://www.ctekbatterychargers.com.au/ctek-xs-08.html
    I'm led to believe they're the best on the market.
    Ebay seller 4wdextreme has cteks cheap . Harley do one for around$55- .
  • Coopsta
    Coopsta
    Try ebay,i bought the harley brand one off there.You attach the leads & just leave the plug sticking out just under edge of seat so when i get back from a ride i just plug it in & forget.Works a treat!!
  • Soapbox2627
    Soapbox2627
    I got a Harley one from Peter Stevens after they left the cable for one on my battery after rebuilding the engine.
    $55.00 ish
    I wont buy Battery Link again (got it from AutoBarn) - I emailed them about buying extra bits and they didn't even bother replying.
  • Darke_peak
    Darke_peak
    Blah
  • brush
    brush
     thanks for the info, i will check out the ctec sounds like the go, in the middle of renovations on my house and havent had much time to ride so the old wide glide is getting a bit hard to start at times.  CHEERS   BRUSH
    They are pretty basic and the same at how they work, at least the ones are that only trickle charge motorcycle batteries so brand shouldn't matter too much. I'm sure there'd only be a few factories making all the brands anyway. Don't get sucked into buying an expensive brand name.
