Online: Merv
Rubber Burnt Onto Exhaust
  • crookneez
    crookneez
    Hello again
    Had my first ride today on my new FXST and loved it. Except I made the mistake of touching the V&H Big Radius with the back of my glove and now I have burnt rubber marks on the pipes
    I'm worried about damaging the chrome removing it so does anyone have an answer to this issue? I'd really appreciate it.
    Thanks
  • 06 Softail
    06 Softail
     Hey mate, just get some brite shine and rub on it, don't worry too much, it will come off pretty easy. Just wipe off with a clean rag after.
  • mickle
    mickle
    Purple Polish.
  • crookneez
    crookneez
    Will those polishes dissolve the rubber or just polish it off?
    Harley actually make a boot stain remover for just this very thing .... and it works very well .
  • scotti
    scotti
    All of the above , white spirits or metho is another great chrome cleaner , or if ya not to fussy just carefully use a razor blade then polish it .
  • FLSTC
    FLSTC
    Start with patience...... then some kero
    Works better if the pipes are hot
  • Colstah
    Colstah
    On a similar vein, here's a little tip for the curious (learned from experience).
    Don't rub your finger over the front brake disc to feel how smooth it is or isn't, right after returning home from a ride.....
    Burnt flesh isn't too hard to remove from the disc....but that's not really the point!!
  • FXST11
    FXST11
    Eucolyptus oil or oil of clove will remove it.
  • Hooky
    Hooky
    I can imagine your reaction Colstah.
    We have coverd this before, The Best and only way is to have your pipes hot and wipe them with a wet rag
  • Maxiboy
    Maxiboy
    Hi mate,
    Go to Bunnings and ask for "Goo Off". It will disolve the rubber and clean the pipes, no fuss!
  • crookneez
    crookneez
    Thanks all, I went to Harley Davidson store today and bought a special bottle of stuff to clean it. Works OK but more work needed.
  • Granox
    Granox
    You just let it get cold and run a razor blade flat at a small angle to the pipes and scrape it all off. Leaves no scratches takes off melted rubber, plastic or anything else.
  • Granox
    Granox
  • Granox
    Granox
