Online: WideglidingNZ
For the South Aussies
  • FISH
    FISH
    Howdy Peoples bit of a ask but here goes as i moved into the CBD recently i have taken all my tools etc up to my streaky property and i have no space either to work on my bike so is there anyone on here that has the tools and space to let me fit my shotgun shocks up and seeing i'm a shit spanner maybe a little help or guidance. I beleive you sort of need two people to hold the back wheel up and connect the front bolts so i was hoping seeing its still shitty weather maybe someone may be able to help .
    Cheers Wayne
  • 06 Softail
    06 Softail
     Hey Fish, PM me your ph number, I will be home today after midday if you are stuck. Have tools, garage, and bike lift if needed.
  • AJ56
    AJ56
    Don't you need the the adapter to take off the shocks from a softail?
  • FISH
    FISH
    Way the weather clearing maybe a ride this arvo is on the cards !!
  • 06 Softail
    06 Softail
     If you have any offers of help from other people Fish, I won't be offended, as I don't know when my wife will go into labor, & I guess after bubs is born, it might be difficult to arrange something.
  • AJ56
    AJ56
    Fish according to the manual to take off the rear through bolts you need an attachment to get in between the mounting frame for the shocks and the swing arm. It is like a ring spanner with the other end to fit a 1/2"drive ratchet. However I have never taken off my shocks, it is just what the manual says. Someone might be able to chime in and offer better advice though.
    What year is your bike?
  • AJ56
    AJ56
     Mate I am working all week but am free next weekend.  I have the bike lift and other tools etc but not the adapter.   Note the mounting bolt No1 That is a close fit between the swing arm and the frame.
    Once the rear mounting bolts are off it is an easy job.
  • FISH
    FISH
    AJ i will ask Blair at bikeworks tomorrow he should give me the right answer if i ask nicely and thanks for the offer as well as 06 softy ive got this covered just got to make sure we get the tools right .Thanks fellas.
    Cheers Wayne
  • FISH
    FISH
    http://www.shotgunshock.com/instructions.html
    sorta tells me just normal spanners will do it it AJ but will keep checking to be 100% sure
  • FISH
    FISH
    http://www.hdforums.com/forum/air-suspensions/709119-teh-new-shotgun-shock-install-thread-how-to.html
    This also gives the idea normal ring and open enders should be the go and a socket set and we are in
  • FISH
    FISH
    Now AJ i expect you study this so i can just hand the spanners and hold the beers
  • AJ56
    AJ56
    Fish you are a funny bugger... No worries
  • AJ56
    AJ56
    Mate no probs... I will get a gas axe if all else fails.... LOL...Have you figured where to put the compressor??? I should have everything you need. Barring the adapter. but I have a set of spanners that will fit... Just not sure about the torque to tighten them up.... We can sort that out on the day....
  • Nomada
    Nomada
    Looks like a good opportunity for a get together.
    You could be on to something Norm , sounds like Fish is supplyin the piss , and we can all stand around tellin  AJ , " nah , I wouldn,t be doin it like that ! "
    Fish - Please Note - VB cans thanks .
    Bringin stubby holder and advice ....
  • FISH
    FISH
    NO NO NO Tim I get the beer and you get to work and maybe a beer with the team after you and AJ finish
  • AJ56
    AJ56
    Somehow me thinks I am getting the raw end of the deal here... However more hands make light work... And the blame can be spread far and wide when it all turns to shit.
    Ya mustn,t be a friend then .. And ya can,t come around to AJ,s cause there,s beer , not raspberry cruisers ....
    The Very Best Davutch , and I gave up drinkin when guzzling came along .
