Online: wildchild, Trunksie
Harley Detailer in Melbourne?
  • BMWHD
    BMWHD
    Hi everyone,
    Does anybody know someone who details Harleys in Melbourne?
    This is my first Harley Davidson, I don't really know where to begin, nor have I the time to spend many hours labouring away.
    Thanks.
  • Big Steve
    Big Steve
    Not that I use them but Peter Stevens do a full detail when they service your bike.
    Unless your bike is really fucked up or for shows, just ride it, wash it every two weeks or so - and polish the chrome as (hardly ever) needed.
  • Deadwood
    Deadwood
    It would take longer to ride it to a detailer than to wash it.
  • BMWHD
    BMWHD
    In that case.
    How do I go about cleaning it? Can you guys suggest some products for the chrome polishing etc.
  • mickle
    mickle
    https://www.facebook.com/pages/Reaper-Motorcycle-Detailing/106704926084623?ref=stream
    Fucked up the shortcut but its called Reaper Motorcycle Detailing and he is mobile so he will come out to your
    place or work.
  • terroristone
    terroristone
    use CT-18 in a spray bottle, scrub with a brush from a dust pan, use a sponge on tins. pressure wash clean, blow dry with compressor, and if you want to get a bit fussy use mr sheen and hd engine brightener. This will bring your bike upto show room clean, and should take no longer than 1 hour.
    T1
