Online: WideglidingNZ
Fatboy wheel bearings and spacers?
  • El Skitzo
    El Skitzo
    I'm about to do a rear wheel swap in my Chopper to replace the spoked rear wheel with a solid Fatboy rear wheel which I'm just cleaning up at the moment.
    The replacement wheel I've been told is out of a 2000 Fatboy, and has sealed bearings to suit my 3/4" axle which is great.
    My question is, am I missing some large washers that sit against the wheel bearings that my spacers will butt up against (like is the case on my spoked wheel with tapered bearings, show below), or do the wheel spacers just sit up directly against the bearings on these later wheels?
  • AJ56
    AJ56
    Nope just the spacer. The spacers just butt up against the bearing inner face. I have a picture of the wheel if you like showing the relative parts.
  • El Skitzo
    El Skitzo
    Yes that pic would be great AJ
  • AJ56
    AJ56
  • El Skitzo
    El Skitzo
    Outstanding AJ, thanks very much for sharing that, exactly what I needed to see!
  • AJ56
    AJ56
    most welcome
    What aj has said if you buy oem ones thay come with one end tapered so just get those ones cut down/machined to suit your application I do have the part number of the ones I just used if you want as thay where only about $14 each instead of $35
  • El Skitzo
    El Skitzo
    Tapered down so the spacer only touches that silver ring I can see at the center of the bearing I assume?
  • AJ56
    AJ56
    Yep, The spacers are supposedly tapered to fit on the bearing face on the center ring.
  • AJ56
    AJ56
  • El Skitzo
    El Skitzo
    Ok cool, that will be easy enough to do when we're making them to length on the lathe. Thanks for the tip!
  • El Skitzo
    El Skitzo
    Ok I've made up my spacers and just got hold of all the chromed bolts I need for the disc and sprocket, and am ready to bolt the whole lot together and get the bike back on the ground.
    One last question though, should I be using blue or red loctite on these bolts when I put them in? I've been doing a lot of research into it for this application and while my gut instinct is to use blue, everyone is recommending red as the chromed bolts need that extra help and are more likely to back out than regular bolts.
    When I first got this wheel the sprocket was still bolted to it and after getting the bolts out with a rattle gun we found evidence that red loctite had been used, so I'm confident my bolts could be removed in future.
    blue is fine and torque wrench them spec and you don't need too drown the thread in it either
  • El Skitzo
    El Skitzo
    I've decided to play it completely safe and in the end I've gone with red loctite, as I'm not taking any risks of them backing out and fouling on the lower left sissy bar mounting bolt as it's only 2mm away so that would happen before you know it.
    Thanks everyone for all your input on getting this Fatboy rear wheel sorted. I've just finished putting the bike together and I'm real happy with how the rear wheel looks, much better than the old spoked wheel in my opinion.
  • 883n Harley Convert
    883n Harley Convert
    Loving the Dunlop Elite's on that solid wheel mate, the look really good!!
