Online: Adam76, softfat
Engine work on Ironhead.
  • jorgo
    jorgo
    Hi all,
    Just found I have some damage in the top end of my ironhead.  I can rebuild it all at home but would like to have the bottom end checked out by someone first.  Can anyone recommend a builder for ironheads?  Id like to send the cases with just the bottom end in and have it checked out, trued etc if needed.  I'm in melb but would probably just courier it to the shop so doesn't matter if its in Melbourne or not.
    Thanks for the help
    Aaron
    with the top end off  from the outside without pulling the crank apart its'a bit hard ,  if she feels a bit loose rebuilt her as it could have been years before if not never rebuilt
