Online: beaglebasher
Fat Bob Help Needed
  • JimD
    JimD
     I have a 2012 FXDF that was recently dealer fitted with a power commander 5 and dyno tuned.
    The dyno sheet looked spot on - good power & smooth torque curve but....
    Ran like crap on the road - lots of decel pop & just did not feel tuned.
    Take 2/ Took it back to the dealer and they spent half a day with it on the dyno.
    The result was a very similar dyno sheet but they added a lot of fuel down low to cure the decel popping.
    Bike ran brilliant for a week - rode it 3 times.
    Bike sat around in my garage for a week as we had freezing weather and some rain.
    Next time it started and straight away it did not sound right - idle sounded weak.
    Bike is vibrating more and feels out of tune again????
    Took it back to the dealer and no fault codes all seems fine (to them)
    Any ideas? -  I'm thinking electrical but not sure where to start
    Why make it your problem, give it back to them to sort out, that's what I would be doing.
    If you start playing with her, they will shift any blame off themselves and while shes under warranty use it.
    Could be electrical, pinched wire, oxygen sensor, numerous other things.
  • JimD
    JimD
     Well it looks like I'm on the right track....
    I stole the missus's blowdryer and unplugged all the PCV connectors and gave both sides a good dose of hot air to dry them out.
    Test rode the bike and its smoother and not decel popping anymore - still not 100% but a signifficant improvement.
    Next I'll do the same again and put some more dielectric grease in the connectors before buttoning them up - there was a little already on the connectors with one of them looking pretty dry.
    Wondering what other connectors may need the same - will be looking at all the fuel related sensor plugs.
  • fundi
    fundi
    what fuel you running
    mines a bitch with anything other than bp 98 octain
    once ran 95oct and i first thought i broke an engine mount it ran that rough
    and no power
    cleaned out the fuel and has right ever since
    fundi
  • JimD
    JimD
     98 fuel did not help - bike is running rough again.
    Unlugging + hot air on connectors only makes the bike smoother for a short period
    idle sounds weak and a bit erratic, bike has more vibration especially around 2.5-3k, feels out of tune & down on power
    Will be going back to the dealer again!
  • Builder bob
    Builder bob
     Hi Jim D
    Hope the dealer sorts out the issue with your bike
    Sorry I have no mechanical knowledge whatsoever so am useless to you
    do you have any mods on the bike
    was it running fine before the ttuner did they load the correct map? Stupid questions but something is definitely wrong with the work they did
    curious to know how much horsepower it develops as I am thinking of going the same route
    i have2013 fatbob 103 cu s&s slipons.
    Want high flow air and tune to go on at first service
    good luck sorting yours out
    bob
  • JimD
    JimD
    Bike is heading back to the dealer today so hopefully they can find what I suspect is an electrical issue ie bad connection, sensor or component!
  • Clutchboy
    Clutchboy
    What was the outcome?
  • ozymax
    ozymax
    fuck that's a week, looks like it's got them fucked. don't accept it until you are completely happy with it
  • JimD
    JimD
     Well I picked up the bike the other day.
    They couldn't find anything wrong with it....Told me that their main mechanic took it for a ride and thought it went well.
    No diagnostic red flags or faults and they did not think anything was wrong with it and that was all they could do!
    I'm getting pretty pissed off and also questioning my sanity at this stage.
    It still ran like crap on the road and talk about vibration!!!
    This morning I disconnected the Power Commander and hooked up the O2 sensors again.
    Went for a ride and its smooth as silk again (for a Dyna)
    Bikes going back this week and they can try another PCV in it as the one I got MUST BE faulty.
    Will update when I get it back.
  • Mungo
    Mungo
     Hey JimD, I know how you feel, theres nothing worse then the stuff around! you question your sanity and you think why the fuck did I bother, stick with it and I hope you get it sorted mate!
  • Builder bob
    Builder bob
    Good luck with it JimD
    if you can notice such a difference with/without parts plugged in must be an issue. I'm sure you have done this but try to isolate each part 1 by 1 so as to narrow it down for the mechanic at the dealer. How I don't know but you want bob running sweet so worth persisting.
    Let us know how you get on.
    bb
    Oops just saw this was august last year. What a moron I am.
    How did it work out JimD
  • Lushy
    Lushy
    Maybe the firmware in the PC V needs updating,before you panic. Most guys do not do this.
