Online: brucefxdl
confused about shocks
  • jamo
    jamo
    I'm lost in shock world trying to work out what to put on the back of the dyna. getting good and bad reports on progressive. my weight is around 100kg and i want to ride 2up at times any one able to help or point me in the right direction with out buying a set of every range till i find the best.
  • FXST11
    FXST11
    Hi, I weigh about 100kg and ran IKON progressive on the rear on my last bike. Deffinately 100 % better ride. Plus with Wife on back they were Great. Have been told HD, OEM shocks are only good for 90kg and for a limited amount of K's from New.
    The Brand Progressive are cheaper, but I wanted Aussie made, Plus when you ring Jeff at IKON at Albury, He will ask you weight and how often you carry a Pillion and extra weight. He makes them to suite YOU., They are not a One Suites ALL.
    IKON around $575 .Custom Made to your door.in a couple days.       Progressive Brand   around  $400.  One size suites all.
  • ozymax
    ozymax
    maybe air
    Very happy with my progressive 430 series shocks . Chrome inner suits my bike , and hand adjustable ( no spanner ) for preload . $440 del . Don,t be confused , just ask .
  • Aussie XB12SS
    Aussie XB12SS
     Progressive 970's on mine & extremely happy. Perfect for single or two up with luggage.
  • Harry28
    Harry28
     Ricor shocks on mine and very happy, Wasn't happy with progressives 418 series. Bang for the buck the Ricor shocks are right up there. Built for weight and riding style.
  • F- BOB
    F- BOB
    + 1 IKON
  • jamo
    jamo
    cheers for the replys called ikon this morning they want $770 per set didnt think they would ask that much
  • jamo
    jamo
    beagle i only got offered one option from the lady i was on the phone with,
    thanks for the offer to try your set but I'm down in Sydney cheers anyway.
  • Hicksy
    Hicksy
    G'Day Jamo,
    Just fitted progressive 444's to me widey and they work good.
  • amcchucky
    amcchucky
    Can' beat the Platinum Bleed and feed air system, if you can spare the cash and time.
