Online: beaglebasher, tussuck, Hilly
Bleeding brakes with ABS
  • Red FLHTK
    Red FLHTK
     Can anyone let me know if there is anything special with replacing and bleeding my brake lines on my 2010 FLHTK with ABS?
  • ozymax
    ozymax
    I did it on 2012 fxdf ABS no problems. Just used a vacuum instead of pumping just to be on the safe side.
    Originally I asked the dealer about it and they told me best if they do it to ensure no air got in the ABS module
  • Red FLHTK
    Red FLHTK
     I'm at the point where $120/hr to service my bike is not on. I want to start doing things myself, but searching threads on this and other forums everyone's got a different opinion. I'm picking up my workshop manual tomorrow and hoping the straight forward answer is in there.
     I'm no expert, researching your question you don't want air in the ABS module, some people recommend reverse flushing, see vid attached.
  • Red FLHTK
    Red FLHTK
     I've had a look at other you tube vids and they were done on a 2008 road king with a vacumme pump, looks easy enough. I don't know if they have ABS though. It'll do for the wife's 2008 XL 1200 though.
  • Retroman
    Yes "suck" it thru' with a vacuum pump. NO LEVER PUMPING !!
    Have a "bleed buddy" top up the master cylinder as you go , they're quite small in volume and empty REAL quick
    Be as careful as , the DOT 4 is a "Kont" on paint so cover up the tank and guards but still be CAREFUL !!
    Also be careful of fluid on the caliper itself , same reason , RINSE with water , don't wipe !!
  • Red FLHTK
    Red FLHTK
     Thanks retro man, you've reinstated my confidence. I'll order the mighty vac and give it a go!
  • luckyone
    luckyone
    changed my lines on a heritege new master cyl and bled not a problem the trick is once its hard tape up your lever and let it sit over nite and any air you missed will come out
