Online: FONTANA302, Merv
Stage 1 FXDF
  • JimD
    JimD
     So I had the Fat Bob dyno tuned the other day.
    Came in at 84HP and 101TQ
    The shop told me that it produced the best result they had seen for a non cammed bike.
    What do ya reckon?
  • JimD
    JimD
     yep stock 103
    Stock header with cat removed
    V&H 3" Slashcut Slipons
    V&H Vo2 intake
    PCV
  • ozymax
    ozymax
    good out come, bet it rides better all round after the tune. I suspect the shop wants you to feel good or they do many 103 stg 1, that is about normal for that set up.
  • Normthe1
    Normthe1
     Interesting.  I just got mine tuned and got 80hp and 100fp out of my stock 103 with SE Race tuner, heavy breather and D&D Fatcats.  Similar numbers but the curves are pretty different.  Blue is baseline run before the tune, red is after the tune...
     Cam is next
  • Ando
    Ando
    dyno sheets are different norm yours goes up in 10hp increments jimD is in 20 but looks similar to me
  • Normthe1
    Normthe1
    Bugger me, I did not notice that...
  • JimD
    JimD
    Yes its interesting to see what a similar bike dynos like.
    The biggest difference is probably down to the pipe with the FatCat being a 2 into 1 its got a bit more meat down low by the look of it but seems to drop off faster than my setup. Is this the norm for a 2into 1?
    I read that the D&D fatCat really wakes up with a good cam installed!
    The stock header 2 into 1 into 2 makes good power (with the cat out) and sounds the business with free flowing mufflers. If your'e on a budget (as I am)  its a good option.
    I didn't care for the sound of the Vance & Hines slipons with the cat still in.
  • ozymax
    ozymax
    with you vast knowledge of tuning and your new member attitude I am sure you won't be missed
    We are all so much better off with him on this site ........
  • inmate
    inmate
    My old busa could do 300kph+ so my harley don't need a tune....
    Anywho, it's all in the tune. A good tuner can make or break a bike. Seems like okay results up the top, be nice to see the difference with a cam added.
  • ozymax
    ozymax
    rocky many of the tuning modules will be good enough for just pipes and A/C so no real need for the dyno if you put in the time doing your auto tunes.
    Get on a japper any japper and stop the revs at 6000 and see how fun they are to ride. No good comparing a HD with any other bike they are completely different animals and almost every regard.
    But don't under estimate the power potential of a HD. Just go out to the strip and have a look at what can be achieved on a street ride able HD, Busa killing potential
  • JimD
    JimD
     For me its not about how fast you go but how good it feels while your doing it!
    A good running bike = "MORE SMILES PER MILE"
    If youre lucky enough to get it running nice without a tuner then count yourself lucky - but then again you won't ever know how much better it might have run with some tuning.......
    Mine needed richening up quite a lot down low to eliminate pretty bad decel popping from the pretty open pipes.
    Bought the bike with the dealer Stage 1 download which just did not cut it.
