Online: beaglebasher
Will std pipes from a 2012 fit a 2011 FXDWG
  • Black1
    Black1
    Before someone has a dig, I need a set of standard pipes for re-licensing purposes.
    Currently have V&H Big Shot Staggered, but don't have any standard pipes.
    My bike is a 2011 FXDWG, I was wondering what year pipes fit my model
    have seen a few sets of 2012 ones for sale, will a 2010 fit ?
    would like to know they fit before I purchase.
    Have previously borrowed a set but don't want to keep doing that.
    Any help would be appreciated.
  • fleabitten
    fleabitten
    O2 sensors are a different diameter, Smartpartz make a baffle for the V&H big radius - don't know if they will fit the big shots, but worth a look.
    http://www.smartpartz.com/SPZVHBR.html
  • ==ShaDoW==
    ==ShaDoW==
    cant you just get some baffles and pack the pipe to pass?
  • Lizard
    Lizard
    2011 have 18mm sensors 2012 have 12mm you will need a set from 2011 or earlier but check the sensor size, I am fitting a 2011 set of Thunder headers to my 2012 this weekend I had to get 18 to 12mm reducers for the sensors
  • Lizard
    Lizard
  • Underground
    Underground
    Yep, they changed sensors in 2012.
    Had to wait 3 months for pipes when I bought my bike.
