Online: speedzter
Throttle Cables
  • Sparra
    Sparra
    Hey fella's...I change my bars on a regular basis...Wondering if anyone has any tips to getting the tiny circlips off the cables that hold them in the bar housing...
    Cheers...Sparra
    Yep. last time i put some new switch blocks on a bike, i just pulled em through with the clips still on.
  • Sparra
    Sparra
    Thanks for the reply's,i'll give it a go...When I put my apes on I took the clips off and put them back on once installed but it was a pain in the arse...Hopefully they will just pull through...
    Cheers...Sparra
    Just give em a quick spray inside the switchblock with wd40 or some spray grease first. It will make pulling them out a bit easier!
