Online: Merv
HDs at Shannons Sydney Auction 21/07
  • Rains
    Rains
    Shannons have several interesting HDs at their upcoming Sydney auction this Sunday.
    See Lot X - Is that all a WLA is worth (coming off a collection, seems in good nick)?
    NB: This post is just FYI only - I have absolutely no connection to Shannons or any of the bikes being put up for sale. ;)
  • SuperGlide
    SuperGlide
    oh yeh, thats some good bike porn.
    Lot X... hmmm
    Love the 67' beemer too!
    When i win lotto tonight, i will buy lot g as i have the perfect spot at home for it. I will always know where to find the g-spot.
  • Neo Dutch
    Neo Dutch
    Lot P is about right.
    Lot X is overpriced.
    Lot E is cheap.
  • Hound_Dog
    Hound_Dog
    Some nice bikes there......Lot P aside...what an abortion.
  • Rocky2010
    Rocky2010
    Some of those old dungers are getting expensive
  • 883n Harley Convert
    883n Harley Convert
    I never knew HD made a scooter?? That would be a very cool edition to any collection!!
  • HIALEAH
    HIALEAH
    Davidson Topper
    Harley-Davidson Topper
    1964 Harley-Davidson Topper
    Manufacturer
    Harley-Davidson
    Assembly
    Milwaukee, Wisconsin, USA
    Class
    scooter
    Engine
    10 cu in (164 cc) 2-stroke single-cylinder engine with reed valve
    Compression ratio
    A: 6.6:1
    AH: 8.0:1
    Top speed
    46 mph (74 km/h)
    Power
    9 hp (6.7 kW)
    Transmission
    continuously variable transmission, between 18:1 and 6:1
    Suspension
    Front: leading link
    Rear: swingarm, two extension springs
    Brakes
    Front and rear: 5 in internal expanding drum
    Tires
    4.00 x 12
    Wheelbase
    51.5 in (1,308 mm)
    Dimensions
    L 75 in (1,905 mm)
    W 24 in (610 mm)
    H 37 in (940 mm)
    Seat height
    30 in (762 mm)
    Fuel capacity
    1.7 US gal (6.4 L)
    The Harley-Davidson Topper was the only motor scooter that the Harley-Davidson Motor Company ever produced.
    Design and specifications
    The Topper had a 165 cc (10.1 cu in) single-cylinder two-stroke engine mounted horizontally between the floorboards. The engine required a premixed gasoline/oil mixture. The starter was of the rope-recoil type similar to lawnmowers or the Lambretta E model. Unlike most scooters with enclosed engines, the Topper's engine did not have a cooling fan.
    It was expected that the low, horizontally-mounted engine would be cooled by air passing under the scooter, but some Toppers developed overheating problems. The engine used a reed valve in its induction system.
    The engine powered a continuously variable transmission that included a safety device that did not allow the scooter to move from rest at engine speeds higher than 1800 rpm. Final drive was by an exposed roller chain.
    The Topper had 5 inch internal expanding drum brakes on both wheels. The front brake was controlled by a hand lever with a parking brake lock; the rear brake was controlled by a pedal.
    The front body, front fender and floorboards of the Topper were made of stamped steel, and the engine cover and body were made of molded fiberglass.
    Development
    The Topper H was introduced in 1961 (sold through 1965) with a new alloy cylinder head that increased the compression ratio to 8.0:1, the transmission placed in a sealed oil bath, a reusable foam air filter, and revisions to the cylinder ports and air intake tube.
     A detuned version of the Topper was also available, with the power restricted to 5 hp (3.7 kW).This was advertised as the "Topper U"
    Performance
    In 1959, a Topper was ridden from Bakersfield, California to Death Valley and back without repair or adjustments requiring tools. The route went through Trona, through the Mojave Desert to Stovepipe Wells, on to Badwater Basin, the lowest point in North America at 282 ft (86 m) below sea level, then to Whitney Portal, 7,851 feet (2,393 m) above sea level on the side of Mount Whitney, after which it returned to Bakersfield.
  • Neo Dutch
    Neo Dutch
    Here's another Topper Harley.
  • SuperGlide
    SuperGlide
    Hey thanks a lot for that Rains, good man.
    I couldn't make it on the day, appreciate that champ.
