Online: Hilly, FONTANA302
1.25 Pull Back Risers
  • Sparra
    Sparra
    I am wanting to put my standard bars back on my wideglide but want to use 6" or over pull back risers...I can find heaps for 1" bars but none for 1.25" bars...Anyone know where to get some???
    Cheers...Sparra
  • robots
    robots
     Hey Sparra,
    harley are the only ones who sell them, dead set
    cost is $215 I think,  you could also look at jims spacers.com which are 1 or 2 inch spacers that go under stock risers, not curved though so will take bar up and back a little
    Could probably get some street slammer bars or something from burly bars
    thanks
    robots
  • Sparra
    Sparra
    Thanks for that Robots...I'll chase some up through harley...
    Cheer...Sparra
  • 45WL
    45WL
    Sparra
    I put some of the genuine set
    on my WG.
    Unbelievable improvement but you will need to purchase the high density bushings as the stock ones feel like putty with huge amounts of play
    Easy as to install ;-)
    Post some pick when you done
