Online: Stuart
Borzilla
1/3
  • ozymax
    ozymax
    Any one using a D&D Borzilla on their dyna?
    trying to find some real world opinions rather than hear say.
    Max
  • GTpeter
    GTpeter
     Hey Max
    Nice note and good quality ,no complaints
    Pete
  • carbon fibre
    carbon fibre
    Been runnin a Zilla for two years on my Dyna, they are loud.
  • Bagger Bob
    Bagger Bob
    Yep as old mate said load  very load sound great at full song , bit tiny with a total different  sound to my old V & H pipes . And yes 10 hp more .
  • ozymax
    ozymax
    they look good. I thought they were much longer.
    There are 2 different baffles for them so maybe don't need to be VERY loud.
    And from the USA guys on a big motor 10hp seems normal difference, all builders I have spoken to over say get the Zilla
    Not the pipe I wanted but can't get that and the zilla was strongly recommended
    Thanks for the pics and info guys.
  • SuperGlide
    SuperGlide
    I've sold 2 sets of these mate 1 guy have'nt heard from but 2nd guy was wrapped,
    (asked for pics/vid for the site but have'nt recvd as yet).
    Tossing up whether to get for my own 110' Fatbob but now thinking maybe D&D Bobcat
    as nobody has tried (other than Sporties) and would like to do something different/guinea pig myself! lol
    + should be very high/good lean anlge on BobCat.
  • Ando
    Ando
    Bobcat on a mates new Streetbob
    [URL=http://s307.photobucket.com/user/Ando1450/media/WP_001525_zps5282111b.jpg.html][/URL]
  • SuperGlide
    SuperGlide
    wots the word on it from ur mate Ando??
  • Sparra
    Sparra
    What are Borzilla's worth...I'm looking for an alternative to my Bassani Road Rage pipe...
  • ozymax
    ozymax
  • Sparra
    Sparra
    ...Bassani's are looking good...
  • Sparra
    Sparra
    Quite a few have tried them and are happy with them...JJ makes no secret of the M & M similarities...Maybe a pm to them would have been in order...
  • ozymax
    ozymax
    Yep same sites but still not cheaper than buying it here
  • ozymax
    ozymax
    fair enough mate. I am building a 124 and the zilla is about the only on the shelf pipe with descent sized and steped headers
  • carbon fibre
    carbon fibre
    Zilla, stepped headers? Hmmmm!!
    I know their catalogue says stepped, but mine is not stepped in the way I believe "stepped" should/could be.
    As far as I can see headers are 1 7/8" start to finish, that is where they blend from 2-1. Now, reading DnD web site they state different od's from the blend point on.
    So stepped header? Not so sure.
    But , performance is second to none, regardless of my ramblings.
  • Ando
    Ando
    2012-2013 Harley-Davidson
    Dyna motorcycles
    D&D 2 into 1 Boarzilla Exhaust pipe.
    2:1 Boarzilla is a stepped header system
    at the head is 1 7/8" to 2" at collector
    and 2 1/2" where the muffler goes to the header.
    All Boarzillas full systems are equipped with
    heat shields,exhaust gaskets, bolt kit and baffles.
    Each exhaust system is designed and dyno tested
    in our facilities.
    Our testing is done with the Harley Tuner's.
    Every pipe is designed to increase low-end torque
    and horsepower.
    Performance increases are about 8 to 10 percent on
    stock motors but may very with built motors
    with the proper tune on the bike.
    I reckon ya spot on CF
  • ozymax
    ozymax
    Carbon it's only what Ando posted pretty much the same as RB Racing system, short of getting a set of guppy pipes made which could take up to 6 months there's not many options with larger down tubes.
    But I think I agree with you and it's not what I in visage as a stepped header. My idea is 17/8" -2" part way down - 2 1/4" at collector -2 3/4" at the muffler.
    The Zilla does seem to be a favorite with the USA boys but maybe thats the bagger gang.
  • carbon fibre
    carbon fibre
    I'm pushing 140hp thru mine, no issues. Similar torque also.
    On a Dyna.
  • Ando
    Ando
    I would have a zilla on my Softy but they just look crap on the Softies, on the dyna's they look cool
1/3
