Online: BoltLeftover
adjustable levers
  • Steve L
    Steve L
    after heaps of great advise about the grips thought I would see what are the best levers to use. My biggest problem is the brake lever, as I am only a shorty I don't have big hands and struggle to get a decent grip on the brake lever. On the jap bikes I have owned I was able to buy adjustable levers which helped heaps. I have done a search but not able to find an adjustable brake lever, only an adjustable clutch. Kuryakyn Boss blades seem to be about the only option I can find, does anyone know of any other closer reach ones,
    cheers Steve.
  • HIALEAH
    HIALEAH
    I found Kuryakin "Trigger" Levers quite good.
  • Steve L
    Steve L
    yeah I did see them, do they come in any closer to the bars or are they more like stock reach.
  • HIALEAH
    HIALEAH
    I think they are closer, I definitely thought they were better to use than stock ones.
  • carwelder
    carwelder
    Try gilliestooling Harley levers. They are an aussie firm in Melbourne that make adjustable brake and clutch levers for Harley.
  • Steve L
    Steve L
    they look pretty good but might have to save a bit more for them, thanks carwelder.
  • murrumfatboy
    murrumfatboy
    I tried Gilles Tooling levers on my 2014 Fatboy, but there was no recess for the plastic shim to keep it from flappin' around!. Returned for a refund, thankfully. Have just fitted Roland Sands adjustables from Griffin Spares, look schmick. Went to ride to work this morning only to find that once I was in gear, with the clutch fully in, she was creeping forward and I couldn't put it back in neutral!!!
    Obviously need to tweak the clutch cable adjustment. Lesson #9482 - test ride after making adjustments or replacements, before you are suited up for a winter's ride only to find that the bike is unrideable and you sweat half a litre just to get the bike back in the garage and all your gear off again!!
    Once I tweak it (and test ride it!), will put up some piccy's and feedback.
  • Bucky15
    Bucky15
    +1 for the RSD levers. As you say M'fatboy gotta adjust the cable and levers up properly and away you go. Yeah I reckon' they do look good too.
  • Bucky15
    Bucky15
  • Steve L
    Steve L
    do you find them much closer than stock
  • Bucky15
    Bucky15
    Yeah they are closer. That's my wife's sporty and they fit much neater than originals. As said earlier, adjust your clutch cable and lever etc so you get a good fit and no creeping forward with the clutch in.
  • Steve L
    Steve L
  • berms
    berms
    + 1. For the Oberon levers. Just installed mine and they are top notch.
  • Steve L
    Steve L
    where did you get the Oberon levers from and how much, cheers.
  • Steve L
    Steve L
    I did look there but it will work out to be over $300 posted I reckon, cheers.
    Yep, they are expensive !!
    Great service though.
    I damaged a lever after hitting a kangaroo, and with their levers, you can buy individual parts.
    I sent them an email telling them what I needed, and they sent the parts free of charge, Including post.
    They now have a lifetime customer !
  • murrumfatboy
    murrumfatboy
    Update...took 'em for a spin, tweaked the range a bit, as my gloves tended to hit the faceted cutout section.  Very nice though....
  • Steve L
    Steve L
    are they are much better reach or just feel different
  • murrumfatboy
    murrumfatboy
    The reach is customisable, from way past stock to so close that you can't fit your glove in there! So yes, better reach.
