Online: Stuart
squealing clutch
  • aussie 1
    aussie 1
    Hi guys , I,ve just started on this site so i hope it goes alright .  I hope someone can help me out here with this , i have a squealing/screeching kind of sound that happens when i let the clutch out after  changing gear  ( I have a 1997 Evo softail  with 58k on clock ;) , the clutch doesn,t slip , and when if i carry a pillion the squeal is even louder when changing gear , I checked the clutch adjustment & thats fine , Anyone out there have the same problems that might be able to help , be much appeciated .  Oz
     sound like you will have to pull the clutch plates out  ,  in the middle of the pack is the spring plate with rivets that can fall apart
    Wheel bearing perhaps...
