Spencer Brook Tav. Sunday 7th
  • keith
    keith
    I went through Spencers Brook Rd last Sunday on my way to York around 11.15am the place was closed, not sure what hour they do now ? Was going to stop off for a brew went on to Greenhill's instead.
  • Cartoon Head
    Cartoon Head
    Keith, We were there around 11.30am Sunday it's open although there is a sign saying closed (go figure!) anyway if you walk around the left hand side of the pub you can get in through the side door.
    Just don't take a menu outside otherwise the "happy go lucky" barman will get in a strop lol, they do a good feed though.
  • keith
    keith
    Thanks C/H going out that way again on the 14th with a couple of FIFO guys, will check it out again see what the go is, closed sign was up ? Good menu at Greenhill's also worth a look if your out that way again. Cheers.
  • keith
    keith
    Going out that way on Sunday 14th,Caltex Servo bottom of Toodyay Rd 10.30 if anyone is up for it ? couple of work mates going meet up there also. Spencers Brook,York,Greenhills,Beverley,York,Bottom of the Hill.
  • 13Deluxe
    13Deluxe
    I'm in if its not too wet Keith!
  • keith
    keith
    Good day out again ! Cheers.
  • 13Deluxe
    13Deluxe
     Cheers Keith, sure was a good day out.
    The weather was surprisingly great!
    see you on the next one
  • killerchef
    killerchef
    ^^^ best not advertise scotty. want to keep some points hey.
  • carbon fibre
    carbon fibre
    Please.
    You latte boys be lucky to break the town limit.
  • killerchef
    killerchef
    haha  only sometimes in bursts.  also thinking about when cou boys join us next.
  • keith
    keith
    Hey K/C even got a gravel bit !
