Any one in Melbourne good at gutting Cats ??
  • Bugger
    Bugger
    Is there anywhere in Melbourne area I can take my stock headers in for de CAT ing and do a nice tidy job.
    A price or ball park figure would be great too.
    Thinking of going back to a 2 into one system for my Fatbob I have the slip ons.
    Always get asked by a EPA tested to see the Cat, which is a worry if I have to take it for sound testing.
    Cheers.
     try the local chinesse food shop they chop up cats & wok dogs ,   not walk dogs
  • mickle
    mickle
    be the same as a rabbit wouldn't it.
  • Burnzi
    Burnzi
     Put a little nick in their coat and blow the skim off with compressed air, works a treat
  • Nomada
    Nomada
    If you shoot one up the ass with a .303 they basically turn inside out
  • ozymax
    ozymax
    pretty simple job really. I did my fatbob and cut the window on the OUT side of the pipe so the welds would be covered by the heat shield.
    Digging all the metal wafer out took a while.
  • Bugger
    Bugger
    Ha,Ha.Ha, 4 out of 5 cat lovers fell into my evil trap,,,,,, Ha, Ha,,,,,,,, evil laugh.
    I new it was going to be hard to resist,,,,, thanks Kiwi Dave, us Kiwis are so past animal cruelty we just love to make love to thing that go Bahhhhhhh.
    but keep them cumming anyway  lol (The  sheep)
    cheers the Bugger.
  • ozymax
    ozymax
    I got mine tig welded back in at a shop.
    just used an angle grinder to cut the window and an old screw driver to bash the cat to bits to dig it out.
    Hint. bigger window is better than small
  • 06 Softail
    06 Softail
     Hi there, I got a laugh outta the first few posts, but hey if I lived in Melbourne, I could have done it for you. I'm a welder by trade, and handy with a grinder and cutting discs. Can mig/tig just about anything.
  • Nomada
    Nomada
    can you tig a couple of cats back in...................
    then it would sound purrrrrfect
  • Bugger
    Bugger
    It said in the 2012 Dyna owners manual  theres no cat for Australia models but there is the active flap valve , isn't that part of the CAT system???
    It makes pips run hot in summer was getting pinging from the motor on 32dg up days.
     I ran it with the valve open, the dealer did some thing that kept the vale open but still ran to hot.
    Remember its a stock wideglide/Fatbob 2 into 1 system.
  • ozymax
    ozymax
    cheers mate might just take you up on that one day.
  • Bugger
    Bugger
    Great answers guys,,, those systems are very heavy with slip ons and the bracket system to the gear box is a worry too.
    Still thinking about which way to go.
    But thanks for all your help I have a better understand about gutting the pussy in the pipe and the cat flap.
  • Normthe1
    Normthe1
    Hey Oz, what did you do with the cable running from the active flapper back up into that module in front of the battery box? My Fatcats go on Tuesday and the general consensus seems to be just to blank the cable???
  • ozymax
    ozymax
    pulled the complete unit the day I got the bike.
