Online: Stuart
ABS help in finding what year is needed
  • Tonykanga
    Tonykanga
      Hi guys loking at buying my first harley and would l
    like to know what year bike do i need to buy that  has ABS any model
    i have researched and can't find any info thanks
  • mickle
    mickle
    2011 upwards, and welcome.
  • Tonykanga
    Tonykanga
    Thanks mate
  • fatboyrob
    fatboyrob
    check out Harley ride days to see what model suits you first before you worry about ABS or not
  • rob.williams
    rob.williams
    Mate you are on the right track, ABS is a must on a bike. Nothing worse than a back wheel lock up on a fast corner.
  • rob.williams
    rob.williams
    2011 cvo convertible with a faulty part on the ABS, and yes you can lock the back wheel up
  • BillS
    BillS
    I personally think ABS is brilliant, have only used it once in an emergency and a couple of times to get use to the feel of it kicking in. I'm now a big advocate for ABS
