Online: beaglebasher
dyna forward control kits
  • jamo
    jamo
    I have fitted the Harley forward controls to my street bob, all fits great except on the break side the peg sags down on an angle and my foot slides off the peg the shop recommended we put a grub screw in the peg to adjust it back up I have done that and it still isn't working any one had the same problem and found a fix???? I'm thinking there should be a replacement part from Harley the shop has told me this isn't the first time they have seen it Jamo
  • jamo
    jamo
    hmmm2 were yours black or chrome??
    i been told only the chrome have the problem I'll get a picture when i get home.
    on a good note the shop's called me and Harley are sending out a replacement clevis that should fix the problem I'll
  • jamo
    jamo
    not the best pic
    My chrome ones are fine , 18 mths old , different batch . Harley part , take them back . Wouldn,t be fitting a grub screw !!
  • moose13
    moose13
    I had chrome ones fitted to my 2005 Lowrider back in Jan & had no probs...
    Wouldnt be happy
  • jamo
    jamo
    so new clivis come in today same problem !!! so don't know where to go now bought new pegs with rubber on them so my boot grips them.. hope the shop follows this up with Harley for a resolution
  • flacky
    flacky
    I fitted some on my fxdc , chrome, they seem ok and haven't noticed that problem but I'll need to check
  • Daggs
    Daggs
    My chrome forwards are fine, might be the actual peg not the forward control hardware itself
  • Daggs
    Daggs
    Swap the left with the right, that might tell you
  • jamo
    jamo
    Got a new set of harley pegs today with rubber on them so my foot don't slide still with the same angle
  • jamo
    jamo
  • robots
    robots
    Hi,
    What about with the stock rubber foot pegs?
    I bought some of the o-ring chrome hd ones and decided to try on passenger mounts and they wouldn't go all the way in when folded up yet the rubber stock ones were no worries
    Thanks
    Robots
  • jamo
    jamo
    bike didn't come with stock rubber pegs when it was mid mount it had the chrome from factory and the 2 sets i have up in pics are genuine HD
  • chopa
    chopa
    it appears the mounting hole for the peg is slightly out. I would be asking for a new set
  • jamo
    jamo
    front, rear, left or right peg makes no difference hope Harley come to the party soon, still waiting to hear back from them
  • Daggs
    Daggs
    I could fix it in about 5 minutes but you shouldn't have to with new expensive parts. Dob of weld on the peg to build it up on the inside so it sits where it needs to.
  • jamo
    jamo
    yea would fix it. drilled and taped a grub screw into a peg already and fucked the chrome
  • jamo
    jamo
    borisat I'm in western Sydney.
    what shim??the one that goes between the male and female clivis with the bolt through it?
  • jamo
    jamo
    so HD head office in Sydney have replied to the dealership saying there aware of the problem there is no fix from them and there not willing to look into one. great to know I'm not the only one this has happened to now to play fix up HD's shoty manufacturing and to start looking elsewhere to mod my bike if this is the support we receive. just to add to this the dealership has been great and in no way is this a reflection on them.
