Online: Retroman
better headlight bulb
  • robots
    robots
     Hi,
    i upgraded the bulb to one of those Philips 30% better light jobs but it was little improvement, high beam is nice but not supposed to ride with that on
    it was a typical wattage globe 50/65 maybe, from there it jumps to 90/100 watt globes i  think
    The led and hid units are probably worth the money or some extra spots, hard with the wide glide brother don't wanna ruin the style of the bike
    thanks
    robots
  • chopa
    chopa
    Get urself some narva or Philips Plus 100 or plus 120's
    I'm running olus 100's and definately better than standard
    + 1 on a better globe get one from supercheap ultra blue or white they are heaps better there is all so a mode that you can do at
    the handle bar switch (cut one wire and join it to the other )so when you go to high beam the low beam stays on as well never got around
    to trying it but but apparently is a winner found on a yank site a few years ago and one of the members said he had done that to hes bike several
    years ago and never had any problems
  • HogBag
    HogBag
    Put a relay or two into the high and low beam lighting and then try different wattage globes.
  • Nomada
    Nomada
    Anyone had troubles with HID, heaps of xars have then nowadays and their blinding.
