Online: Retroman
Security light 2011 Softail
  • Stuffa
    Stuffa
     The security light is staying illuminated after arming which I believe is means there is a trouble code. My question is how can you access and clear security trouble codes on my bike. I found plenty of info on earlier models but not later models
  • 06 Softail
    06 Softail
     Hi there, AJ56 a forum member here, recently posted a whole heap of codes etc, and how to remove them, in the last couple days, now I can't remember the thread it was in. Keep looking in either general workshop threads or maybe the EFI threads. Good luck.
  • 06 Softail
    06 Softail
     Gee that was quick AJ, cheers for posting the link for the OP.
  • AJ56
    AJ56
    Pure arse that I logged in and saw the post...
  • Stuffa
    Stuffa
    Thanks all. I came across this while I was looking because some of the trouble codes I came across weren't listed.   https://m.box.com/view_shared/71403c9cb40ad878d156  . It has all the codes for later model bikes. After I cleared all the old codes it just ended up being a blown low beam globe. Anyway hope this helps .
