Online: Wanderer57
Pin Removal - Video
  • kingchops
    kingchops
    UH,
    Handy to know, especially when you've got to remove wiring through a tight space or hole. I did it the other day when I swapped over my headlight housing, only way to get the wiring out in tact was to remove the plug.
  • Deadly
    Deadly
    Which reminds me
    I accidently and without noticing removed the wires from the rear O2 sensor from thier plug under the oil tank while mucking with somthing else. Took me 1/2 hour just to find the damn plug.
    Does it matter which way round this plug is wired or did I just get lucky on the old 50/50 thing.
