Online: baldy1450
powder coating
  • beaglebasher
    beaglebasher
    i need to fit a 5/8" square bar into the square hole in a corbin  brand seat.  i measured the bar today and its  0.621" . i painted it with flat back paint and it still fits in the hole but a little bit tighter. my question is how thick is powdercoating?
    It depends on the type of powder...
    Thermoplastic resins need to be classified as.
    PVC
    Nylon
    Polyester
    polyethylene
    polypropylene
    There are two application methods for thermoplastic resins.
    Fluidized bed technique ...... results in coating thicknesses between 5-12mils.
    Electorstatic spray ....... results in coating thicknesses between 3-5 mils.
    Thermosetting resin yields a coating thickness of 1-2 mils.
  • beaglebasher
    beaglebasher
    thanks for that tussuck, its gonna be too thick
  • HogBag
    HogBag
    Black chrome will work on the back rest post. If you want to use powdercoat just have it done on the top half of the post just above where it go's into the leather cover.
