Online: blueystar
Muller Power Clutch Kit
  • 45WL
    45WL
    Yeah call me a girl, call me what you like but the clutch pull on my 96 sporty was killing my left hand.
    Oiled the clutch cable - there was a slight improvement but nothing dramatic
    After some more research (couple of beers in front of the laptop) came accross the Muller Power Clutch Kit and decided to order one through M&M
    Installation was really easy
    1. Remove derby cover
    2. Remove stock unit from clutch cable
    3. Assemble and install Muller Power Unit on cable end
    4. Close everything up and adjust cable
    5. Test ride and readjust
    Verdict: Clutch pull effort is significant reduced but there is still sufficient pressure to "feel" the clutch and I dont get cramps in the left hand from riding in traffic -happy days
    Hope this helps someone out there with the same problem
    Cost?
  • 45WL
    45WL
    about $175 including fedex from m&m
    not cheap, but its made the world of difference to me
  • terroristone
    terroristone
    Thank you, i've been trying to find a clear cut review without the bullshit. I'm sold. I'll order one next week.
    T1
  • ozymax
    ozymax
    I tried one a few months ago on a dyna. much much easier on the leaver pull BUT it also reduces the travel of the clutch pack and would drag at the lights in gear.
  • ozymax
    ozymax
    yep tried all sorts of adjustment just couldn't get it right.
    changed back to stock ball and ramp and went with a bandit sportsman clutch and it's fantastic
  • 45WL
    45WL
    I did the 1/8 turn adjustment as per the instructions, I dont feel the clutch dragging
    To clarify the clutch isnt super soft, it still has sufficient resistance and "feel" when engaging and disengaging
