Online: blueystar
Harley no lights no start no nothing
  • CVOCVO
    CVOCVO
     Hi everyone
    I am new on this site and have bought my first Harley which is a 2007 CVO Springer Softail. I have only had it a few days and have ridden it with no issues until tonight.
    I went out and tried to start the bike - Nothing! No lights came on, no instruments lit up, no actuation when starter or indicators were tried.
    I put new batteries in both FOBs ( the right way round) still nothing
    The little security alarm key flashes every few seconds as per usual and if I try to move the bike it will glow continuously for a few seconds. If i keep moving the bike the alarm will carrry on. which is ear splitting. It is as though the FOBs arent there and not disarming.
    I tried the disarm trick etc but still no action.
    The battery is brand new. It started perfectly and easily earlier today.
    I had to fiddle witht the ignition knob on the tank yeaterday as though a contact was dodgy.
    Fuses all ok in the box under the seat. The master fuse is OK, the battery fuse also looks OK.
    I have no idea what to do next.
    Can anyone please help? I love this bike and cant wait to ride some more
    Thanks
  • Mr_Bean
    Mr_Bean
    I think you may have found your problem with the ignition switch.
    I've had to pull the main inigtion switch apart [really easy a small circlip holds everything together] gave it a clean and put dielectric grease onto the contacts.
    re-assemble... takes about 15 min to complete...
    Cheers,
  • cm364352
    cm364352
    Remove the dash and spray some WD40 into the ignition switch,while turning the switch on and of.
    WAZ...
  • CVOCVO
    CVOCVO
     Thanks for your replies everyone. The problem was simply an ignition switch connector. A five minute fix!
  • Retroman
    CVOCVO Where are you located mate ?
  • CVOCVO
    CVOCVO
     South Oz mate
