Online: Stuart
Welding/Custom fab Perth
  • Asher
    Asher
    owdy
    I've got some bits and pieces I want to get modified for a little Ironhead project I'm working on in Perth.
    First up is a bit of fabbing:
    - A front fender/fork brace I'd like lengthened
    - An aftermarket frisco tank that I'd like the cam style cap replaced with a screw in.
    I've got all the bits and just need someone who can weld better than me (a lot better)
    Any suggestions for where to get this sort of work done in Perth?
    Asher
    gavin forbes forbes + mills engineering Wangara 9309 3373 he is a pain to get hold off leave a message he rings back one man show he is on holidays at the moment
    he will be doing some work for me in a few weeks
  • Asher
    Asher
    Thanks,
    I did a bit of internet stalking on the guy:
    I run a busniess that specialises in motorcycle engineering. Machining and fabrication, welding of aluminium, magnesium, steel, stainless, cromoly and titanium, repair and refurbishment of most parts on a motorcycle, frame straightening, engine and cylinder head repairs. Cylinder head performance work. Glass bead blasting. Anything from current model to the oldest of vintage. we will do work that a mechanic will not or can not do.
    Sounds good
  • El Skitzo
    El Skitzo
    Go see Brett at Hand Made Vintage Kustoms in Malaga, custom bike fabrication is what he does all day every day!
    31 Westchester Road, Malaga (rear unit)
    Phn: 0424 161 152
    BTW I just had a cam style cap swapped for a screw in style recently on my custom tank, good move!
