Online: Stuart
throttlepak
    Any one tried a V&H Throttlepak on their bike.
    Can you do the same result with a powervision by overiding the electronic butterfly in the manifold?
  • conmore
    conmore
    Hi there
    I installed a Throttlepak on an 09 Electra Glide Ultra Classic (stock 96ci engine, hi flow air filter and Supertrapp 4" Stout mufflers). Had terrible throttle lag down at very low rpm like from around 1500rpm and also in the mid range. really annoying compared to a cable operated system.
    There was some discussion about adjusting throttle plate sensitivity using a Tuner and software but I have zero experience with that so I purchased a Throttlepak to try it out and it worked an absolute treat!!! Lag gone!
    Throttle snap was back. And hesitation gone. Took me 30 minutes to install: :)  See here: http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=7&postid=435944&view=topic
    Ta, have sorted it via the power vision tuner. Not perfect but certainly better
  • gidgi
    gidgi
     mine arived Today ,now to put it on
