Online: beaglebasher, Wanderer57, FatMat
VIBRATION ON DECELLERATION
  • fatboyrob
    fatboyrob
    Has anyone else come across a vibration / thumping  coming through seat area when backing off on throttle on a roadking, happens at most speeds
    its not a metal on metal sound , more of a thump thump thump
  • Retroman
    Engine mounts ?
    Never owned a Roadking myself , but plenty of Dynas over the years ( same same...)
    First place I'd be looking mate
  • terroristone
    terroristone
    check the rear wheel/ bearings and tyres as well.
    T1
    Let the dealer take a look first Rob. Hopefully it will be something simple.
    I would start by looking at the engine mounts too.
    Engine mounts
  • taff60
    taff60
    Engine mounts? I put a post about it in tech. Its warranty if ur still in date. If not,an eazy fix,
    Also check head bearings. Might be feeling it further back. And of course seat bolts and contents of panniers!
    he's only had his bike for a month, i would take it straight back and get them to look.
  • taff60
    taff60
    One month? Take it back. Dont touch it. Dont take no for the answer.
  • Stewy
    Stewy
    Loose tank bolts? Mabey
    Took me awhile to find that thump
    They looked and felt tight but not tight enough to pinch up to the frame
    A few more ft lbs did the job
  • fatboyrob
    fatboyrob
    tighten all nuts & bolts today, found heaps not quiet enough. Went for ride this afternoon all is good, back to the way it was when I when I first picked it up from dealer
    Thanks every one for advise . rear top box should be here tomorrow, can't wait. stereo will now have six speakers
  • AJ56
    AJ56
    Just check that the bolts have had Loctite applied, I have found all bolts on the HD's require loctite blue for all removable bolts. Especially mounting and engine fasteners.
