Online:
Hilly
SE 37951-98 HD clutch spring
Daggs
Howdy all,
Have ordered the above spring to help fix clutch slippage after cams and big bore to my bike, I'm assuming (hoping) it comes with install instructions, meanwhile I'm just looking through my workshop manual wondering where exactly it fits in with the existing clutch components?
I guess it just replaces the stock diaphragm spring. I thought it might have been used in conjunction with it.
KiwiRob
It replaces the stock spring. Will need to eat your spinach, as your left fore-arm will get a good work-out. A muller power clutch (real good but pricey) or White bros or similar, easy clutch kit will help. - Rob
Daggs
Cheers Rob, yeah I've heard their heavy but stock is very light so I'll see how it goes other wise I'll look at what you've suggested
KiwiRob
There doesn't seem to be any difference in the clutch travel or any problems with dis-engagement when using the Muller Power Clutch. No experience with the other set-ups. - Rob
