best product to clean denim black??
  • WarDaisy
    WarDaisy
     hey guys..
    Justwondering what is considered the best product for cleaning the denim black ..as im unsure if my meguiars products that I use on the car are suitable. . Dont wanna try and potentially cry...r
  • gidgi
    gidgi
     mate I just used windex. a quick wipe on wipe straight off , always in the shade & never polish that paint it just dont work. cheers
    I use this clear shit called water. Hasn't failed me yet.
  • RaynMan
    RaynMan
    I had been using windex as per a lot of reccomendations from various forums, however, No matter how careful, no matter what the cloth (microfibre) I always end up with streaks using windex. Last week I decided to use plain ol water with my microfibre cloth. Came up perfect. So I'll be sticking with H20 from now on.
  • RaynMan
    RaynMan
    I was a sucker an opened the Damn link. It ended up displaying this log. I know SMTP is outgoing email relates but does anyone know what this might have done? I can probably expected a multitude of spam though.
    SMTP -> FROM SERVER:220 mx1.main-hosting.eu ESMTP [Main-Hosting.eu Mail System]
    SMTP -> FROM SERVER: 250-mx1.main-hosting.eu 250-PIPELINING 250-SIZE 20971520 250-ETRN 250-AUTH PLAIN LOGIN 250-AUTH=PLAIN LOGIN 250-ENHANCEDSTATUSCODES 250-8BITMIME 250 DSN
    SMTP -> FROM SERVER:250 2.1.0 Ok
    SMTP -> FROM SERVER:250 2.1.5 Ok
    SMTP -> FROM SERVER:354 End data with .
    SMTP -> FROM SERVER:250 2.0.0 Ok: queued as 88FCC4BC3CC7
    Message sent!
  • Jayman6
    Jayman6
    Mate best advice is run a scan from your anti virus software (hopefully you have some) and monitor your emails and any other program's/websites you use a password for. Change your email password and your password for this forum also. If you use a standard password for lots of things then change it. Do this ASAP mate.
  • RaynMan
    RaynMan
    I'll take your advice, cheers.
  • Jayman6
    Jayman6
    If your anti virus scan comes up with any trojans, maybe start a thread about to warn others. These things can range from anywhere to some geek just distributing malware to be a cunt, to legitimately sinister motives I.e obtaining passwords for your banking, PayPal, eBay etc...
    So why hasn't that link been removed?
  • 1340nev
    1340nev
    wash mine with soapy water then wen its dry windex wipe on wipe off .
  • Harry28
    Harry28
    I use wax & grease remover or metho for those oily greasy hand prints that seem to appear from nowhere.
    4th of June 2013 this topic was started....
  • Harry28
    Harry28
    Got some stayin power eh!
  • FAT TONY
    FAT TONY
    Coles furniture polish - brown can like Mr Sheen
    used it on the Fatboy, the sportster and now the the nighttie
    looks like new
