Touring Shocks
  • Sparra
    Sparra
    On the recommendation of a few in here I have a set of air shocks on the way off a Road King...I find the progressives I have on at the moment a little too stiff so I will see how these new ones go..What I am wondering is that if they leak is the bike still ridable with no air in the shocks...
    Cheers...Sparra
  • Sparra
    Sparra
    Thanks CW...I already have 412 progressive's but I got the heavy duty ones so I will try the air shaocks and see how they compare...
    Cheers...Sparra
  • Sparra
    Sparra
    A lot of good reports on the us site as well...If they are not for me I will sell them on and keep looking...
  • Deadwood
    Deadwood
    Had some on my Dyna. Worked really good. Used to run about 15-20psi.Only thing I would do is put some heavier oil in them which was recommended by a few.
