Online: HD17, Wanderer57
80 cube exhaust system?
  • contractor
    contractor
    im looking at updating my system, iv got an 1988 softail with the 80 evo, now iv looked at waynes systems as well as V&H, samson etc, when i was in jap land a year or so ago, i met a couple of jokers that made there own systems for every bike, im guessing they copied others.
    i'am very "buy aussy" orientated, can i get or entertain the thought of a 2.5" or 3" system thats made here? or should i buy a mandrel bender :)
    my exhaust is part of a cam and carby update that iv taken advice from you guys about a few months back.
  • skirtster
    skirtster
    It would be much cheaper to buy mandrel bends from an exhaust shop and weld them together, to build your system
  • contractor
    contractor
    then chrome them? i thought the pipes were tuned to perform thats why they cost so bloody much
  • contractor
    contractor
    so today i spent a good 5hrs looking for a fukn system and found nothing but v & h or nothing that stood out. to be honest im thinking of just going VCM
  • contractor
    contractor
    thanks dyno Harley, iv been looking for something alittle less mass produced and different, looks like il need to go V&H
  • contractor
    contractor
    I run/ran a set of 2-2 Supertrapps on my 86 Evo and they are awesome. They are brushed stainless and are not that common.
    2.5 or 3" pipes au look nice, but your bike will run like total chit with them unless you baffle the crap out of them to get back pressure.  More pain than the gain IMO.
  • sag57
    sag57
    l ran a supertrap 2 into 1 with the racing open end cap with a SE4 cam, 42 mm Mikuni and fuck did that old girl rev and pull,. Unless your running a big inch motor stick with the 1" and 3/4 pipes
  • contractor
    contractor
    ok thanks fellas, I actually fukd with the baffles and freed it up then wrapped the headers with the exhaust wrap, it looks ok, im going to start beding up my own set soon. I have a mandrel bender.
