Online: snoozy
fitting 10" mini apes
  • Steve L
    Steve L
    Hi all just wondering what is required to fit 10" mini apes to my Heritage softail 10/07 model. I can get a set of bars from Rollies for $215 plus $40 for the wiring extensions, do any of the other cables need replacing,
    cheers Steve.
  • beagle
    beagle
    Hi Steve, Didn't it have high bars on it when you got it, so the existing cables may fit. Unpicking the harness plugs is the pain if you go internal wired bars. The stock bars on new heritages changed and are now apes, and half the price you've been quoted. Just an option to consider.
  • Steve L
    Steve L
    Hi Alan,
    it came with the fatboy bars but did originally have the standard bars, are the new Heritage bars internally wired or external, cheers Steve.
