RevTech 4 pot caliper
    don't know about the revtech but I brought a brembo caliper from fleabay was about $300 deliverd its a 4 spot comes with pads and a bracket kit I did change the pads to lyndall though cant say how it is on the road I havnt ridden the bike yet will try and add a pick later
    Hope this works first time using a iPod to do this
  • terroristone
    terroristone
    id dont see the point in using cheap alloy crap, especially where brakes are concerned. You spent how much on your bike? To go and fit $2 ebay brakes??? Every bike i have seen with cheap calipers fitted has had problems. Spend a few dollars more and dont risk your life, and other road users lives.
    T1
  • terroristone
    terroristone
    Performance machine, willowood, brembo are the only brands I would trust.
  • FXSTB95
    FXSTB95
    I'm off Performance Machine - bought new PM forward controls and the master cylinder was faulty. It took $146 of work by the bike shop to make it work.
  • wayco
    wayco
    I would probably add Nissan to the list of good calipers -standard equipment on most Jap bikes & Triumph & probably a few others-
    4 & 6 piston -Cheap & available new & second hand -plenty of spares.
    You probably have to make your own adaptor plates?
    Just a thought.
  • terroristone
    terroristone
    Very good point Wayco, but if you have to mod anything (make brackets) then you will require and engineers certificate to make it legal, if not its another reason for your insurance company to knock you back...this may apply to any upgrade to your brakes......just food for thought....
    T1
  • wayco
    wayco
    T1 is correct -but even alot of the aftermarket kits that have adaptor plates could be rejected and even ones that bolt staight on.-not ADR approved
    The modification issue is a very subjective one-my bike had a vass engineering assessment done because I moved the brake pedal from right to left-(among other mods )Vic Roads then imposed a set of conditions & conditional registration requirements that were unexpected by the engineer-depends on the Vic Roads assessor as to HIS/HER personal opinion -not necesarily logic or law.
    To be safe I used all Harly parts -V-rod brakes ,M.cyl ,discs ,wheel etc under the multi fit policy Harley has-engineered for insurance  /police purposes -so that it didn't become a contentious issue.
    With exhaust as an example -a person would assume any exhaust that complies with the DB rating of the bike should comply ,but some inspectors ,require stock only -relying on the $$$ factor for you to fight it and arguing that it doesn't have adr compliance.
    Whilst aftermarket parts often exceed OEM ,unless they have some sort of compliance attached ,its like walking into a mine feild.
    This is just my experience-got reemed once -didn't enjoy it -don't plan on the Gov't reeming me again if I can help it.
  • terroristone
    terroristone
    Very true wayco, i've had to engineer many many many cars and know how had it can be, bikes on the other hand im yet to have to engineer one. Personally on my bike i opted for a direct bolt on HD caliper (xr1200) which can fall into the "owner approved mods" section, as the caliper has been tested and passed ADR standards and it is a direct fit for the "sportster" series of bikes which required no mods to be done.
    T1
  • wayco
    wayco
    I don't think a late brembo will bolt on to an 87 leg-I think you will need a 99-2000 & up leg for a bolt on solution.
    I also think that they both use 41mm tubes so it should be straightforward-but check with a mechanic/dealer first.
    its sold buy a guy on the us ebay hes user name is taraqtmi has over 600 + positive feedback sells lots of these calipers aswell as discs
    I just had look he hasn't got anything listed at the moment the caliper kit with pads sells for $189 .00 us plus post .hope this helps
