Street glide speaker issue
    Anyone had a problem with their std speakers not working on Street Glides or Ultra? The rt side speaker started crackling then gave up completely. I removed the fairing and if you juggle the speaker wire tou can get it to start, seems as though there is a break in the wires somewhere in the loom. It is booked into the dealer on Monday as it is still under warranty.
    No dramas with mine PB. but only done 6000ks so far.
    Do you travel much on bumpy roads, maybe a wire is loose in a connection. but as you state , let the dealer have a gander.
