Online: beaglebasher, Stuart
Wanted 103 Dyna Stock pipes
  • Normthe1
    Normthe1
     I know this should probably be in the Parts section but I'm only looking in WA so will give it a shot.
    I'm looking for a set of stock 103 Dyna pipes, any condition, just need them for a bit of a project.
    If anyone in Perth or surrounds could let me know if you have a set you want to get rid of, please let me know.
    Cheers,
    Norm
  • Retroman
    Norm
    remember the 103's have a different O2 sensor setup from the 2011 and earlier bikes
    Different O2 sensor size in a different location. NOT easy to interchange !
    The Dyna platform changed for 2012 models.
    Probably best to list the model/year you're after as well mate
  • Normthe1
    Normthe1
    Thanks Gregg. 2013 FXDF is the model...
  • markmckenz
    markmckenz
    I really dont know if this helps but I have 2012 (same as 2013) FXDB pipes sitting in the garage.
    Stay in Belmont
  • Normthe1
    Normthe1
    Thanks anyway Mark, I found a set, cheers...
