08 leaky brakes
  • Hoodaman
    Hoodaman
    Hay yoall....just had the RKC in to the shop to look at leaking brake MC....They replaced to cover and rubber as it was damaged by the fluid and was told they had seen quite a few with the same problem.....now i have to take it back again as the problem is still occuring so i suspect it is the actual MC body perhaps not even at the lid.....Has anyone else had this problem on thier 08's?    I am led to believe it could be a common problem???  at least in Sydney....
  • Hoodaman
    Hoodaman
    Thanx Scotty..now just wonderin if they replaced the seal???i think not but dont think there will be much prob goin back again.....got me stuffed though its only two screw......ta mate i will ask em about the seal.....
