Online: baldy1450
Okebay-cheap sunglasses
  • ozymax
    ozymax
    so whats the site?
    I got a set of willie x and they are great except for the finish which is failing after 6 months. Time to go back to cheapies
    Your site has gonnnnnnnnnnnnnnnnnnnnnne
  • ozymax
    ozymax
    yep after the last pair I don't think any of them are worth more than $16
  • shingles
    shingles
    ah would you put cheap cheap parts on your bike i mean there is quality sunglasses out there ,i ve gone down dat cheap road with things an it all ends up in bin ,ive been wearing gatorz sunies made in usa outa aircraft aluminum and a lifetime garranty, these r really well made i tried bendin da arm an fuk me nothin happened lenses are some supertough shit  an sum lense changein shit ,i got polerized lenses polished frames ,would i recomend this product shit yeah look up GATORZ SUNGLASSES im glad i did they are metal ive dropped on lenses by mistake was expectin da worst clumsy twit ,but no damage 2 lenses coupla dints in frame ,but u could polish out or file out then polish on metal wheel ploisher coz they is actually aluminum SHINGLES
  • philthy
    philthy
    Well I can rub salt in the wounds. I've been wearing the same sunnies for a coupla yrs now, Spotters,Thunder model,with brown lense. Been using them for riding (incl mower) whipper snippering,Gamefishing,all the time on me dial outside anywhere.Need em up here in the tropics. The thing that stops me losing them is a fluro coloured strap,which makes it easy to see them when I put em down,or their hanging round me neck. (Not on top of me head at midnite like a fuckin trendy) .......I wore the same sunnies across the usa on me  84 softy (when it wasn't busted down!!) in 2003. I've had the lenses replaced due to stone chips and wear/tear since then, but the same frames.Drop of any oil on the hinges once a yr!! But it is all due to a $6.50 fluro strap. I change them when they turn from fluro any colour to brown from dirt... Worth a thought guys......
    Had a uglyfish strap on here,with the infamous sunnies. It was 2003 with Olly Downie (ripped back tire on his bike) and the Mexican towie. I pretended to have the shits for the pic,but seem to have fucked that up too. Probably something to do with NO FUCKING SLEEP FOR 3 DAYS DUE TO SLEEPING ON THE SIDE OF THE RD FROM BREAKDOWNS!!  Long sunnies story but WTF
