Online: tussuck
How to change floor boards on fat oh and add pegs
  • Poolj
    Poolj
  • Aunty X
    Aunty X
  • Poolj
    Poolj
     Hi Aunty I was looking for info on how to change flloor boards on a fat boy to pegs.  A y ideas cheers
  • Poolj
    Poolj
     Hi all been trying to get some info on how to change floor boards too pegs on Harley fat boy, anyone got any ideas. Just recent started using this forum not sure if anyone has replied although it looks as if someone sent me ?. Can anyone help.
  • Aunty X
    Aunty X
    Can't help, sorry.
  • fatboyrob
    fatboyrob
    stick with Harley ones they make a kit, bolts straight on, just have to order pegs , fit better than after market ones, don't have to change rear brake pipe.
    kit comes with all screws, every thing you need except pegs. will make your bike corner so much more
  • fatboyrob
    fatboyrob
  • Poolj
    Poolj
     Thanks for your reply. Now on track.
  • LBDave
    LBDave
     mate, I just had my fatboy lo converted to pegs, last week. I agree with fatboyrob, go with genuine Harley gear.
    Mine done by Harley Heaven in Adelaide, cost Parts - $441.00 includes new break pedal.
    Cost labour $265.00 brakes have to be bled also.
    I loved the boards when I bought the bike, but scraping started to give me the shits. The pegs are Fukn A++++ I can lean the bike now.
  • Steve L
    Steve L
    any pics of the before and after conversion
    Be careful what you wish for. Boards are very comfy on long trips
  • wayco
    wayco
    I've done reverse conversion on a deuce-pegs to boards-its pretty straight forward-remaove & replace-I think I used a new master cylinder with the boards so had to bleed the brakes.
    I do remember that putting the brake clevis was a bit of a pain in the arse but that could be because of the vance & hines exhaust i have.
    Not sure if you need Torx bits -a manual will tell you that.
    Its well within the average DIY person.
  • Poolj
    Poolj
     Thanks to all u guys for the info.
    Cheers Justin
