Online: John.R
Help needed to change 2010 Road king handle bars
  • Boppa
    Boppa
     Hi folks,
    I'm just about to remove my standard road king handle bars and replace them with Stock Harley heritage bars but l have 2 questions.
    When l took off the removable plastic ring that surounds the steering lock l noticed that there are 2 security screw holding down the chrome cover that covers the handle bar clamps.
    What is the best way to remove these screws so l can remove this chrome cover.
    The other question do you need to do any mods to the stock heritage bars to fit the throttle by wire.
    I have heard that you need to groove out the end of the handle bar to suit the Throttle by wire .
    Also do you need to shorten the handle bar end of the throttle by wire end as the throttle by wire sticks out a bit from the end of the handle bar .
    Any help would be much appreciated
    Cheers Boppa
  • Boppa
    Boppa
     Thanks for that slup .cheers boppa
  • Boppa
    Boppa
     Thanks for that info Puz, that is great instructions .It does'nt get much better than that.
    cheers boppa
