Online: Stuart
11 RK another oil leak, how serious?
  • mr.gimmick
    mr.gimmick
     hey guys,
    noticed a bit of oil, i guess, between the rear cilinder and engine case, still under the 2 yr warranty, wtf, does it need an engine rebuild or what?
    i've only have 11k k's with it.
    will this be covered by the warranty?
  • Outlaw01
    Outlaw01
    Yep definatly !!! Base o ring is leaking as Hmmm 2 said
  • Rocky2010
    Rocky2010
    Take it back to the dealer, they will fix that under warranty.
    Friend of mine has a Dyna and his crankcase was leaking oil from the casting not any joint, problem was with the casting being porous and the oil just kept on weeping through the casting..
    They disassembled the complete engine to fix the issue, also had new crankcases installed repacing the original ones.
    I think Evinrude Outboard motors do the castings for Harley Davidson.
    LOL...nice to see the newer twinks have the good old base gasket leak that us Evo riders have.
  • Hoges1974
    Hoges1974
    fark mine has way more than that and everyone told me they do that if you flog them ?????
