Online: beaglebasher, Hilly
starter problem
  • allyoop
    allyoop
    Hi
    I've just fitted a starter to my 1200 sportster.
    I hit the ignition, but while it's spinning, it's not engaging with the wheel.
    I turned it off and fiddled with a wire, then tried again. Fist time it sluggishly began to turn it, but then it must have disengaged, and started spinning again.
    Can anyone tell me what I can try next?
    al
  • Colstah
    Colstah
    Another guess here.
    Apart from something mechanically wrong with the spring/shaft/gear, or whatever, the symptom you describe can be caused by a low battery. If the battery is a bit flat, it will have enough power to spin the starter motor, but not enough grunt to 'throw' (engage) the gear which turns the engine.
