Headlamp Relocation/Cable Extension
  • la0055
    la0055
    I am relocating the headlamp on my 2007 Sporty from the stock position lower down on the tree (more of a Bobber look) using a relocation bracket bolted onto the lower tree.
    Problem is with the cable length, probably a couple inches short for the new position.
    Anyone know of a extender/connector that I can use ?
  • Nomada
    Nomada
    Id cut, solder and heat shrink.
