Online: baldy1450
Removing tappet oil filter screen
  • Burnzi
    Burnzi
    Well finally got that shitty bloody slotted screw out, got the spring out......whats the secret to getting the %$&#en screen out?
    A set of tweesers or in my case a surgical clamp. It can be a bugger!
    It should be a cone shape with the pointy bit upwards so should not be that hard though.
    Oh....and spend $15 and buy a socket head screw! My slotted one gave me the chits trying to get it out.
  • Burnzi
    Burnzi
    Thanks Tussuck I had a look on youtube and it showed it on there, easy job and plus 1 on the bolt head, those slotted bastards are ....well they're bastards. Cheers mate and thanks for reply
