Online: Nino
air filter
  • Steve L
    Steve L
    what a difference an after market filter makes, I have just fitted a Roland Sands kit and the difference was definitely noticeable. Surprisingly it doesn't pop or crackle any more than before. I do have an auto tune Thundermax  in the post and will fit it next weekend
  • Colstah
    Colstah
    Looks good.
    You shouldn't be parking your bike like that though....pushies OK, motorcycles no.
  • Steve L
    Steve L
    yeah its got me screwed why my pics are loading sideways.
  • AJ56
    AJ56
    It is how you are taking the pictures. If you are holding the camera on its side that will make them the way they are. If using a smartphone the same will happen. open them in Windows Picture Viewer and then rotate them and save before posting.
  • Steve L
    Steve L
    cheers AJ I will give that a try
