Online: Nino
phone app decibel tester
  • Geoff3DMN
    Geoff3DMN
    Due to the sound sensor fitted to phones they aren't accurate beyond about 90db, above that they're basically useless for anything else than determining which of 2 noises is louder.
    You can get cheap sound meters from Jaycar that are fairly accurate.
    Cheap Jaycar Micro sound meter $39-95
    Better Jaycar Compact sound meter  $99-95
    Semi-pro Jaycar sound meter with calibrator (class 2 compliant) $399-00
    www.jaycar.com.au
  • Nomada
    Nomada
    My app stops at 90. But I think im louder than that so I cant help.
  • Hooky
    Hooky
    Sound meters are a precision instrument used to measure Sound Pressure Levels. I definitely wouldn't trust a 3rd party software application on a "smart phone" if a sizeable fine from the EPA could be the result from a failed test. I've been for 3 enforced sound tests and they told me that if it's not a stock exhaust, it's probably too loud. Unless, of course, you heavily baffle your non-standard pipes and the tester doens't ping you for modifying the exhaust.
    Safest bet, put your stock-o's back on.
    ^ What Hooky said, if you want to pass the EPA you need the stock exhausts.
