compliance sticker
  • Steve L
    Steve L
    just doing a bit of work and cleaning on the bike and noticed the compliance sticker is pretty much illegible. It looks like it is a 12/07 model but no chance of reading anything else. Can I get a new sticker from a Harley dealer or is non replaceable, cheers Steve.
    Why would you need to worry? If anything ever came of it there are govt dept records as to its compliance whether it relates to hd Australia batch compliance for a particular model or a raws workshop compliance on a grey import. Cops typically won't care, and can find out if they need to whether a bike is complied or not. Bikes can't be registered without compliance in the first place.
  • Steve L
    Steve L
    thanks mate I was concerned for when I update or get pulled over for something, would it still get a roadworthy with the sticker illegible. I only just got this bike from a dealer (not a authorised HD dealer) and was surprised it could be roadworthy like that.
  • ozymax
    ozymax
    just go get a new one from the dealer
  • Steve L
    Steve L
    will someone like Morgan and Wacker be able to get one, I got the bike from Heavy Duty at Springwood so they wont be able to help.
  • ozymax
    ozymax
    not sure if it is a 1HD model but if it is 5HD yes or gas alley, picked up 1 last week although they are supposed to fit it.
    you need. copy of license, copy of rego paper, revs check and stat dec stating the vin sticker for bike reg # vin# has been damaged during mechanical work or washing or some crap. and they want $50 from memory, go talk to them they will give you all the guff and can do the revs check but you can do it on line probably cheaper.
  • Steve L
    Steve L
    cheers thanks for the info, yes it is a 5HD model, still waiting for the rego papers to come. I picked the bike up Anzac day so I would have thought I should have them by now, will have to chase the dealer tomorrow.
